my tranny is locked up, Help
2007 gy-5 the tranny is stuck in second , the clutch is working fine. It was working fine then it wouldn't shift at all, gear lever feels like something is hung up.
Mountainwolf had a similar problem on a shineray but this being a different motor I am not sure if the shifter configuration is the same. I have tried pushing in and pulling out on the lever while working it up and down and no go. http://www.chinariders.net/modules.p...ht=shift#34418 |
While his engine looks different on the outside it looks the same as mine on the inside. I would look for the same sort of problem.
Good luck |
Driller,
After my finals are done I think I am going to tear into my bike and do this mod, mine is not stuck yet, but I have had problems while down shifting. might as well cure the problem before it is a real problem. Around the 17th of this month I will be cracking into it. When you do decide to tear into it let me know how it goes. |
Driller, search through the threads. Member Mustang_USMC bought my bike--I had installed a Lifan engine, and the tranny went out. I thought it was over, but it turned out to be a clutch issue.
