Old 05-04-2008, 05:56 PM   #1
mike8349   mike8349 is offline
Need valve clearance specs. for LF250 w/ 2V49FMM
Need valve clearance specs. I cant find them anywhere... Please help.
Old 05-04-2008, 09:09 PM   #2
Buyingchina   Buyingchina is offline
Re: Need valve clearance specs. for LF250 w/ 2V49FMM
This information is normally shown on the "vehicle emissions specifications" tag affixed on the bike. You may find it help full to use a magnifying glass to read the small print. If the clearances are in mm (millimeters -metric) then simply Google "metric conversion" to convert to thousands of an inch (e.g.-.002) by filling in the appropriate fields.
If your bikes tag is missing then post this info, and I'm sure another owner of the same bike will be along to lend a hand.
I hope this helps. Buyingchina
Old 05-05-2008, 11:13 AM   #3
It is on the sticker.. Its just hard to see.
Cold : Intake .03-.05mm
Exhaust .05-.07mm
No conversion needed... We work on Yanmars and its all metric.
