Picture posting
How do I add a picture to my post?
before you upload your pics make sure they follow the guidelines for posting your pics. the max size is 900x600 and the file size can be no larger than 97.2kbs. Check the dimensions of the pics you want to post and modify if needed. I have a Chromebook and use sqoush as a pic editor. Google pic editor and search for an app that can be used on your platform. The process is surprisingly simple. Merry Christmas.
Before we switched server providers the pictures would automatically resize. The problem with previous provider was the site was crashing on a regular basic. With the new provider and updated software, pictures will not resize automatically and the feature is no longer available.
imgbb
The simplest way I have come to is use imgbb image hosting service. When the link is uploaded it must size it to the forum guidelines and then if you want you can click on it to go back to view it in original resolution. You just copy the picture link and post it in your post. There are instructions on here somewhere or I can send them to you.
