Old 11-02-2021, 09:47 PM   #1
Applepilgrim1   Applepilgrim1 is offline
Can’t remove front rotor from hub
I have been trying to replace the rim on my front wheel for a while now I managed to remove most of the spokes except those that are being blocked by the rotor. I’ve tried everything to get the 8.8 size lugs that hold the rotor to the hub off. I’ve even tried a propane torch which I’m pretty sure cooked my bearings. Please if anybody has any advice on how to get these stupid things off it would be very much appreciated. I’m at the point where I just want to get my bike off the stand and ride.
Old 11-03-2021, 07:53 AM   #2
Have your tried using a small impact driver?
2020 Kawasaki Vulcan S
2004 Honda ST 1300
Old 11-03-2021, 06:39 PM   #3
Working_ZS   Working_ZS is offline
You need more heat. Try and find an auto repair shop with an acetylene cutting/welding rig and have them heat the bolts and hub bosses that they thread into, while simultaneously applying torque with a ratchet, hex key, or an impact driver. A small #1 or #0 gas welding tip works well here, allowing you to apply the heat with pin point precision just on the bolt head. Most rotor bolts on Chinese bikes seem to be applied with LocTite Red, or China's version of it, and that stuff will not let go without serious and continuous application of heat. You literally need to be heating the bolt as you are loosening it to get it out. If you back off on the heat before you have the bolt out all the way, the damn thread locker that they use will re-set up on you. I went through this on the rear rotor bolts on my RX3 and it was a royal pain in the rear. I could not believe how tenacious that thread locker was; first time I've ever had to heat bolts continuously to get them out.
After you get the bolts out, I recommend taking a M8 X 1.25 thread tap and cleaning out all of the existing thread lock, then replace it with something a little more forgiving, such as LocTite 242 or 243.
Old 11-03-2021, 08:09 PM   #4
I did try a small impact without avail as Working ZS was saying it needs much more heat than I can give it. I broke down and ordered another hub assembly for 30 bucks the next rotor I put on will use hex bolts. I understand you dont want things moving but damn its like the bolts are spot welded down.
