Old 11-02-2021, 09:41 PM   #1
mcsupersoldier   mcsupersoldier is offline
Where to Get a Hawk 250 Digital Cluster
I'm looking for a digital cluster with speed sensor for my Hawk. Anyone know where to get one? The one I see recommended everywhere from Amazon shows out of stock.
Old 11-08-2021, 11:02 AM   #2
Give this a whirl. It says it in stock.
https://www.amazon.com/Zanella-RPS-H.../dp/B08P8YF75Y
First Rule of Aviation:
The Stable:
2005 Yamaha V-Star 650 - SOLD
2015 Suzuki DR 650
2015 RPS Hawk 250 - SOLD
2016 Ural Gear Up
Old 11-11-2021, 01:16 PM   #3
Skyd   Skyd is offline
Skyd's Avatar
I have the one linked above, works great I even did an install video on it on my channel. Also the price is like $35 lower than when I got it!
2020 RPS Hawk 250 - Build thread can be found here: http://www.chinariders.net/showthread.php?t=28374
"Do Wheelies and Forget your Feelies"
"If vegetarians eat vegetables, what do humanitarians eat?" -unknown
Old 11-14-2021, 11:16 PM   #4
wally   wally is offline
That is the one, bought that same item 2 months ago. 2020 Hawk 250 Carb.
All the other ones won't come with the right harness.
Old 11-14-2021, 11:47 PM   #5
discochris   discochris is offline
discochris's Avatar
And that one won't work correctly with some of the other similar, but not identical, China bikes. It won't work with the Bashans.
Old 11-15-2021, 12:19 AM   #6
FlyingBasset   FlyingBasset is offline
What doesn't work about it? I re-pinned a few wires on each harness and it works fine with my BSR 250.
Old 11-15-2021, 01:14 PM   #7
KenTaoyan   KenTaoyan is offline
KenTaoyan's Avatar
its cheaper than the one I got from there.
Speedo is off and I think the Tachometer is off too. I like it because when I come to a stop light I like to know what gear I am in or when i am cruising and run out of gears. The gas gauge is better but still off a little. (I got a better quality float from CSC)
Speedo = GPS off of phone
Tachometer = I use my ear
Gas Gauge = always best to check visually or keep an eye on the odometer.
Gear Indicator = priceless....
two cents......
~ toys in the cave (in the order of addition)
81 Honda XL185s {work in progress}
2018 QIYI Coolster 3150CXC 150cc Quad
2019 QIYI Coolster 125cc Quad
2021 Roughhouse 50 (neat little scooter for the wife)
2022 QIYI Coolster 3150DX-4
I may not be fast but I am "Half-Fast"
Old 11-15-2021, 07:14 PM   #8
two cents......
I just adjusted mine to the 19 inch wheel setting and now everything is accurate. Seems like an easier option to me.
Old 11-16-2021, 09:51 PM   #9
Thanks for the info all. I just ordered one and can't wait to get it swapped out.
Old 11-19-2021, 01:10 AM   #10
discochris's Avatar
It's been over a year since I tried the Zanella, so I don't recall exactly, but if I remember, the plugs themselves didn't match the BSR harness. I tried swapping wires around but never did get it to work, so I sold it on ebay.
Last week I got the cluster and sensor from AliExpress that was mentioned in the Raven thread, and after swapping the two wires on the one plug, it works really well, though I may need to look at the fuel gauge, so now I'm digital. (of course it's also getting to winter here, so not much riding going on.)
I suspect there's a pretty good chance that these things are cobbled together in different factories and are sold as a one size fits all for China bikes, even though they really aren't.
digital cluster, hawk 250 speedometer
