10-27-2021, 08:06 PM | #1 |
Left engine cover crank bolt access screw
After smelling oil at every stop i looked down and noticed the left side crank bolt access bolt
Is gone, I know I have checked it recently but it must have vibrated a off , wasn’t sure what was going to happen I’d had a 40 Mile ride home but made it ( but the question is where can I get one in a hurry what is the proper name for this and the is there a Chinese MacGyver solution to what I could use till I can get a new one |
10-27-2021, 08:53 PM | #2 |
Gorilla tape. After you get the bolt access cover and remove the tape, use WD-40 to remove any glue left on the case.
10-28-2021, 06:45 PM | #3 |
Stator Cover Crank Case Plug Cap Is what I need don’t know if any Honda models should work which I found some on line, I will try the tape until I can find the part I tried a few Chinese motorcycle dealer and get no response
10-28-2021, 07:12 PM | #4 |
What bike is this on?
10-28-2021, 07:17 PM | #5 |
Wow I can’t believe I didn’t put that in 2020 hawk 250
10-28-2021, 07:57 PM | #6 |
What is the ID of the hole where the plug cap goes?
10-28-2021, 08:04 PM | #7 |
Check with TXpowersports or Orionpowersports as they both carry and sell parts for the Hawk.
10-28-2021, 09:35 PM | #9 |
I was looking for the inner diameter of of the hole, in mm, I stumbled across one earlier today with an outer diameter of 28.3mm, measured at the threads. I know the overall diameter is slightly bigger, and may be match to a Honda one shown HERE. Part #15 is 30mm wide overall, and part #19 (o-ring) is 27mm
10-29-2021, 08:19 AM | #10 | |
10-29-2021, 09:19 AM | #11 |
Unfortunately it has it’s unavailable
