Old 10-27-2021, 07:23 PM   #1
Ten41   Ten41 is offline
What is this exhaust bracket called?
One of the boys forgot to tighten his bracket down as I told him too, and it ended up falling off. But I cannot figure out what in the world the thing is called in order for a new one to be ordered.
It is the bracket that holds (what I call) the exhaust header and the exhaust.
Name:  Bracket Small 2.jpg
Old 10-27-2021, 07:49 PM   #2
It's a sanitary clamp. I don't remember the exact size but can be found on Amazon.
2004 Honda ST 1300
Old 10-27-2021, 08:20 PM   #3
Smile
Wow. That almost doesn't seem right, nomenclature wise.
Thanks!
Old 10-27-2021, 10:25 PM   #4
I saw post few years ago JerryHawk250 said he safety wired his and I promptly did the same. No problems since.
Old 10-28-2021, 08:48 PM   #5
mototech77   mototech77 is offline
mototech77's Avatar
That is a funky name of a part to see on a motorcycle . I thought it was a v-band clamp at first glance.
2021 Lifan Xpect EFI
2012 DF250rtc
1982 Yamaha Virago XV750
1982 Honda Twinstar CM200
Old 10-29-2021, 08:15 AM   #6
I don't remember the exact size. You will have to take some measurements. Here's a link. https://www.amazon.com/QiiMii-Stainl...2s9dHJ1ZQ&th=1
2004 Honda ST 1300
Old 10-29-2021, 10:51 PM   #7
I was curious so I looked up what they are designed for;
Sanitary clamps and hangers are for use with stainless steel piping systems in a food, beverage, and biopharmaceutical applications.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 10-30-2021, 07:27 AM   #8
buzz   buzz is offline
not a muffler clamp for sure
Old 11-01-2021, 03:59 PM   #9
Smile
I don't remember the exact size. You will have to take some measurements. Here's a link...
Thanks Jerry Hawk! That is the exact one we purchased. It was good for him to actually use his mathematics to go from the circumference of the pipe to the diameter. Finally something that he cares about uses the math that he was required to learn.
We received it rather quickly and it did the job perfectly. No more exhaust rattle or exhaust gas bypass to heat up his leg.
Old 11-01-2021, 04:11 PM   #10
Put a safety wire on it and it will never come off again. Mine kept vibrating loose but was lucky it never feel of. After putting the safety wire it never got loose again.
2004 Honda ST 1300
Old 11-01-2021, 06:56 PM   #11
Will do thanks!
Old 11-02-2021, 08:13 AM   #12
Magician16   Magician16 is offline
Those things do have a tendency to fall off. I lost mine sometime in the first 100 miles, but I knew about where it fell off. I searched about 10 minutes before I found it.
2018 Bashan Storm(sold)
2016 Magician 250
