Anyone gotta link for a PAIR block off plate???
Any links, please. Pod air filter and aftermarket exhaust was gonna ditch it.
#2 | |
https://gy6racing.com/universal-egr-...-gy6-scooters/ I used that one on my Orion RXB. Bolted right up. No fuss whatsoever. |
You can make one with a piece of 1/8" think aluminum or steel flat bar. Aluminum will be the easiest material to work with. I've made all of mine out of aluminum. Use the stock gasket as a template.
Jerry saving the day as always!
While we're on this topic - does anyone know what this third tube going from the bypass module is doing? It looks like it goes to the tank but I can't be sure. https://imgur.com/a/lSvFuUK I know left goes to airbox and bottom is from the head - but before I cut this third one short and cap it I wanted to see if anyone has a better solution. Edit: Image isn't displaying so I linked it as well. |
#5 | |
2021 Lifan Xpect EFI 2012 DF250rtc 1982 Yamaha Virago XV750 1982 Honda Twinstar CM200 |
#6 | |
There is another separate set of tubes that do seem to link the crankcase, airbox, and a small filter/valve - so probably just a breather tube - but it looks like I'm good to leave those! |
This would be a good side hustle for someone.. with my old Honda Fury there was a guy who fabricated and sold block-off plates (2 were required) for $15 if memory serves, although it was slightly more complex than what we require here.
These are so simple to make. Personally I wouldn't pay anyone for them. Pick up a piece of 1/8" aluminum flat bar at Lowes or Home Depot for less than $5. Use the gasket and trace it out. A hacksaw or metal cutting blade on a jigsaw makes quick work of it. Drill two holes and file or sand the edges. Less than a 5 minute job. You can make quiet a few from a 3' long bar.
I theaded the hole and used a stainless hex head bolt.
#10 |
I've thought about doing the same but had a piece of aluminum stock handy already.
#11 |
ERG Block Off Plate...
Hi,
Here's a link for a ERG Block Off Plate on EBay. It sells for $5.85 with $4.95 shipping costs (go figure)... Hope this helps... Joe... |
