Old 10-22-2021, 10:00 PM   #1
wvsv650   wvsv650 is offline
o2 sensor bypass hawk DLX
I am looking for resistor info to remove the o2 sensor, richer fuel charge
2021 HAWK DLX
Old 10-24-2021, 11:45 AM   #2
John Holifield   John Holifield is offline
These DLX bikes are too new and parts for them aren't available yet. Even things like installing resisters to cure lean condition or even being able to make changes to the ECM are not really available either. I wish I would have purchased the standard Carbed version because those have been around for a long time and parts and mods are widely available.
Old 10-25-2021, 10:17 AM   #3
franque   franque is offline
I'd leave it alone, the O2 sensor is a necessary part of making any EFI function well.
Old 10-25-2021, 11:38 AM   #4
Leave the O2 sensor in place. You can add a resister inline to the IAT sensor to trick the ECU into thinking the intake air temperature is cooler that it actually is which will make it run richer. Since no one on here has actually done it i can't give you the resister value needed. Resisters are cheap. you could buy an assortment of resisters and start some trial and error testing. Do some Google research. You might run across a forum on tuning small cc EFI engines. It really isn't rocket science. Believe me, if I had an EFI Hawk i would of done the testing myself.
2004 Honda ST 1300
Old 10-25-2021, 11:41 AM   #5
Here's a detailed explanation i read in the past when i was looking into the same thing for my former RX4:
https://www.boosterplug.com/shop/cms...l-version.html
2024 Zuma Storm 150 DLX
2019 Beta 430 RRS
Former China Bikes: Tao DBX1, Brozz 250, CSC RX4, Titan DLX, Templar X
Old 10-25-2021, 03:54 PM   #6
lateracer   lateracer is offline
Cheap and easy race car solution - If it runs without the sensor plugged in, then try that.
Most single sensor O2 setups operate rich in open loop mode while the motor is cold.
Old 10-25-2021, 10:44 PM   #7
rideMI   rideMI is offline
Programmable ECU
Buy/Build a programmable ECU, I think you have Delphi EFI?
Having a programmable ECU you make the engine what you
want it to be. WARNING I have made engines POOF!
Old 10-26-2021, 10:38 AM   #8
What happens when the motor is warmed up and hot?
Old 10-26-2021, 12:22 PM   #9
cycleway4   cycleway4 is offline
with the O2 sensor unplugged,...it will still be in open loop,..which is the reason for leaving it unplugged. until the plugged-in sensor gets up to temperature, it will not go to closed loop.
<div>Steve
2006 Roketa DB-07A/RSX-200E
2008 Roketa 250 Scooter
2019 Brozz 250
Old 10-31-2021, 09:04 AM   #10
When it warms up, it goes to closed loop where it adjusts fuel mix based on air/fuel ratio in exhaust. When cold, the amount of fuel injected is determined by the throttle position sensor.
Haven’t had a chance to go hands on with a dlx yet though, so basing my responses from car world experience.
