Old 10-21-2021, 06:37 AM   #1
muhoboy   muhoboy is offline
muhoboy's Avatar
Auto chain lubricator.
https://aliexpress.ru/item/329535986...509f94b4&tt=MG
Old 10-21-2021, 03:30 PM   #2
Boatguy   Boatguy is offline
Boatguy's Avatar
How does it work?
Does it only apply while you are moving?
2020 Lifan x-pect
Old 10-21-2021, 03:45 PM   #3
muhoboy's Avatar
Dear friend. Watch this video, everything will become clear.
Old 10-21-2021, 03:48 PM   #4
muhoboy's Avatar
https://www.cobrra.sk/en/nemo-2-devi...nd-quad-chains
Old 11-14-2021, 06:06 PM   #5
SGCSCRX3   SGCSCRX3 is offline
This has been something I have been thinking about putting on mine. Keeping the chain oiled up.
Old 11-18-2021, 01:38 PM   #6
krat   krat is offline
With the industry standard chain lube schedule being once every 600 miles don't you think that this goober's lubing recommendation of 3 times daily is a bit strange?
It sort of over amplifies the perceived need for the device more than the need to lube requires.
I can see the need for some sort of auto-lube system if you are traveling from Nome to Tiara del Fuego, doing 500 miles daily and going out of your way to find crappy roads to ride, but the average rider does not do 600 miles a month on and off pavement, and this is simply another gimmick device for the majority.
%90 of the Chinese motorbikes ever made are still on the road. The other %10 made it back home.
Old 12-08-2021, 05:05 PM   #7
Originally Posted by krat View Post
With the industry standard chain lube schedule being once every 600 miles .
Industry standard for chain lubrication...that's a new one for me. I have owned lots of chain and shaft drive motorcycles but the only recommendation I can remember was "as needed". Some bike won't see 600 miles in a year, others in a weekend. Rain, dust, salt grime...the variables are too broad for any set standard. Personally, I find that a very small amount of lube will go a long way. I see the lube as a rust preventer since I am using O or X ring chains nowadays. My last few auto chain systems dispensed the oil based on distance traveled. You can dial in extra lube for riding in a rainstorm or on a dusty road. My last coast to coast ride on a Ducati used about 4 oz total...for a bit over 7,000 miles. The chain was never overly wet but also never bone dry. I think I had over 20K miles on that chain when I sold the bike. The down side was that the auto oiler was expensive, something this gang would not want to shell out for. Hell, you can replace the chain and sprockets for less than $300 and the average rider will never need to do so because the bike gets so few miles while he owns it. http://www.pro-oiler.net/
