10-07-2021, 06:25 PM | #1 |
What Does "Sputtering" Mean? (Tao Motors TBR7)
I was informed that my new 2021 Tao Motor TBR7 may "sputter" with the stock carburetor. I have not noticed anything like that during acceleration or at steady speed. But when decelerating with throttle off, is sputters/backfires a bit. Is that it?
10-08-2021, 10:59 AM | #3 |
Backfiring during deceleration...
Backfiring during deceleration or letting off of your throttle indicates a lean pilot jet. Try going up one size in your pilot jet and see if this remedies it.
10-08-2021, 12:44 PM | #4 |
How does it matter if it happens? Sounds cool actually!
10-08-2021, 03:22 PM | #5 |
The backfiring is a sign of a lean idle mixture. Pilot jets is probably sized right. Try turning out the idle mixture screw to about 1 1/2 turn for a starting point and adjust from there. The idle mixture screw is located on the bottom side of the carb next to the bowl. It will have either a brass or plastic cap covering it that you will have to remove t gain access to it.
10-08-2021, 05:53 PM | #7 |
They would not design it that way.
10-08-2021, 06:06 PM | #8 |
It's designed to run with a stoichiometric mixture of fuel/air at about a 14.7:1 parts air to fuel ratio. You're bike is running too lean, the engine is NOT designed to run under those conditions... too lean and it will be damaged.
10-08-2021, 07:51 PM | #9 |
You are giving the manufacturers too much credit. These bikes are fine for the money, but they lack in quality control and engineering. Braindead0 is absolutely right about possible damage, and JerryHawk250 has great advice on how to resolve it.
It’s your bike though, so if you really like the popping and are okay with engine damage, more power to you
2021 Lifan Xpect EFI 2012 DF250rtc 1982 Yamaha Virago XV750 1982 Honda Twinstar CM200 |
10-09-2021, 10:04 AM | #10 |
No vehicle which is subject to environmental emissions regulations is designed for optimal running; they are designed for passing emissions regs, i.e. they are too lean. If you have a carby bike, step one should be to get the air intake and carb jetting right. If you are not concerned about water splashing onto the filter, or the intake being submerged in creeks, toss the airbox if it has one and put on a clamp-on filter. Then adjust the carb, or get a better carb, to suit the improved air intake.
10-09-2021, 12:57 PM | #11 | |
*Please check with your local DMV to confirm street Legality* |
10-09-2021, 01:49 PM | #13 |
Too listen, is too learn! Just thinking out loud!
10-09-2021, 03:26 PM | #14 | ||
On a side note, the LIfan X-Pect 200 and RPS Hawk DLX with fuel-injection have shown fuel-injection to be mostly reliable remedies.
10-10-2021, 05:38 AM | #15 | |
EFI is great for automatic altitude adjustment, but if it breaks it is not as simple to fix as a carby.
