Old 09-26-2021, 09:18 AM   #1
rdh824   rdh824 is offline
Neutral Safety switch not working
Hi
I have a Taotao 150 ATV and the neutral safety switch is not working. Just finished rewiring the ATV with a new harness and everything else works. The Neutral safety switch was working before.
-It starts when in Neutral
-No Neutral light or reverse lights work.
-Tested Neutral and Reverse Switch with Ohm meter. Both appear good.
-4 wires total from both switches and the greens are wired together-Looks factory? So going into the harness is 3 wires(green and then neutral and reverse wires).
Bad switches?
