Noob question
I will receive my BD125 tomorrow. Everything thing I read says to remove the charcoal canister..but what do I do with the hoses that are attached to it? Should they be capped in some way..traced down and removed at the other side?? Please help
You remove all hoses that are attached leaving only a breather hose for the gas tank and vent hose for the motor case.
You may need a block off plate on the Vaders... not sure. |
