Old 05-02-2008, 09:21 PM   #1
Hydraulic clutch conversion.
Has anyone tried this yet? My cable broke, can't find a replacement locally. The red would look kind of funny on a blue bike, but WTH, right?
Linky
Old 05-02-2008, 09:44 PM   #2
I looked at those and it looks nice and I thought it might be nice if I got stronger clutch springs it might make it easier to pull the clutch in even though I have no problems at all with pulling in the stock clutch.
Wait Wait I cant buy one because of this.
To convert your clutch to hydraulic operation, some moderate creativity and mechanical aptitude will be required.
That leaves me out.
I may get one for the wifes bike since I plan on a set of bars and handguards and that would look great on her bike.
Old 05-02-2008, 11:22 PM   #3
slimjim503   slimjim503 is offline
i have one on my gy5 i like it... got from ebay it for a lifan pit bike works good had it on there 3 weeks now
Old 05-03-2008, 07:48 AM   #4
katoranger's Avatar
Where id you put the mirror? I didn't see a mount for a mirror on that one.
Great option though.
Allen
Old 05-03-2008, 10:32 AM   #5
i used the old perch and cut off the lever and ground it smooth then put the new cluch lever on
Old 05-03-2008, 01:51 PM   #6
DirtRoadKing   DirtRoadKing is offline
So evidently the line is long enough. My concern was that it might be a little short.
Old 05-03-2008, 09:56 PM   #7
no it long it will work
Old 05-03-2008, 10:21 PM   #8
Rizn   Rizn is offline
slimjim, how bout some pics
Old 05-04-2008, 08:31 AM   #9
rigidchop   rigidchop is offline
easy off oven cleaner should take that anodized coating right off.
Old 05-04-2008, 05:19 PM   #10
ok i just got home from work and ill get you guys some pic
Old 05-04-2008, 07:08 PM   #11
I keep hearing that, but I've made too many bombs with aluminium foil and ovencleaner.. I don't want to try it with something I'd like to keep!
Old 05-04-2008, 07:47 PM   #12
the bombs only work because they are in a space, where the air cannot escape. i actually had one explode in my face. good times. you could always use some sandpaper. anodized coatings are usually pretty thin.
Old 05-05-2008, 09:15 AM   #13
The coating came off of my forks when I was cleaning the bike. I sprayed them with Greased Lightning and the color just ran away!
