Old 09-07-2021, 11:59 PM   #1
Bamboozle146   Bamboozle146 is offline
Hawk 250 shift linkage not engaging
Hello, I've just bought a Hawk 250 secondhand from someone, and the shift linkage/bottle opener looking device isn't properly engaging the detent/star gear to properly shift.
We thought we had fixed it, but I took it down the road and it just missed the detent again.
Everything is tight, and looks exactly as it should.
You can also see the PVC spacer I made next to the shift lever in attempt to pull the shift tab closer to the detent.
It IS ENGAGING in the video, but again when riding, it just falls back off and grazes the detent/star gear.
Any help is greatly appreciated.
https://drive.google.com/drive/folde...NF?usp=sharing
Old 09-08-2021, 11:47 AM   #2
franque   franque is offline
A couple of questions... Are all of the bolts pertaining to the shifter system tight? That being the pivot and the shift drum? Also, are all of the springs correctly installed and indexed? Everything looks good otherwise.
Old 09-08-2021, 12:19 PM   #3
buschPilot   buschPilot is offline
there is a plate that looks kinda like a coke bottle opener, it looks like they didn't put it in...there is a video on you tube I got to see if I can find...it should show you what there should be there....
Old 09-08-2021, 12:22 PM   #4
I found it...
Old 09-20-2021, 07:30 PM   #5
Marc Hufnagel   Marc Hufnagel is offline
Hi You mention you drove to Illinois to get it. Was it a dealer? If so I'm curious where it was as I live in Illinois. thanks
detent, gears, hawk250, shiftdetent, shifting
