Old 09-06-2021, 02:20 AM   #1
Bread816   Bread816 is offline
Ordered a Vader 125cc! Parts are on the way :)
Howdy from Kansas City!
I recently ordered a Boom Vader 125cc from Kronic Racing and expect it to be here within the next week or so. I've obviously been doing a lot of reading about what to do when I get the bike and obviously ordering lots of upgrades.
I've made a pretty decent/detailed list of what I've ordered so far and figured I would share with the group as many others are probably in a similar situation.
If there is anything missing from the list or other upgrades you've found that are worthwhile, please chime in.
Rear Swingarm/Axle and Chain Adjust Hardware
Honda AXLE, RR. WHEEL 42301-K26-900
Honda NUT, U (12MM) (FUJI SEIMITSU) 90306-KGH-901
Honda WASHER, PIVOT BOLT 90122-KWB-600
Honda ADJUSTER, CHAIN 40543-K26-900
Honda CAP, SWINGARM END 40546-K26-900
Honda NUT, SPECIAL (6MM) 90302-KBP-900
Honda NUT, HEX. (6MM) 94001-06200-0S
Swingarm Spools
Fit For 2013-2020 HONDA GROM MSX125 Motorcycle Swing Arm Spools Slider Bobbin
(From racing-knightmotor on eBay. I’m sure I will not end up using all of the above hardware, but these will allow you to use a rear-wheel motorcycle stand)
Rear Shock Hardware
Honda BOLT, FLANGE (10X47) 90123-K26-900
Honda NUT, U (10MM) 90304-KGH-901
Air Filter
K&N Vent Air Filter 62-1514
Carburetor
Generic VM22 26mm from Amazon (Brand: LEIMO)
10pc Carburetor Main Jet for Mikuni VM22 from Amazon (Brand: ARJ)
Spark Plug
NGK CR7HIX
Sprocket
428 17T Sprocket Front Engine Sprocket from Amazon
Fender Eliminator
Kemimoto Grom Fender Eliminator Kits from Amazon
Exhaust
MSX Motorcycle Exhaust Muffler Middle and Front Link Pipe Full System For Honda MSX 125
(From Amazon, but not currently available anymore. This is one of the only systems that fit the Grom clones because full Grom exhaust require you to bend the pipe to fit the exhaust port. This item is only the “header,” so you will still need to purchase a 38-51mm slip-on muffler of your choice)
HIAORS Pit Dirt Bike Exhaust Crush Gasket from Amazon
(These are needed when installing the midpipe listed above per multiple reviews)
I still haven’t decided on a muffler yet! I like the look of the “shorty” carbon fiber ones, but not sure yet. Please post pics/suggestions to mufflers you all have found that sound and look badass!
I look forward to being a part of the group!
Thanks,
Brian
Old 09-09-2021, 12:35 AM   #2
Welcome to here! Glad to see Pete has the Vaders back in stock and shipping
Old 09-09-2021, 07:23 AM   #3
TyGuy   TyGuy is offline
TyGuy's Avatar
Welcome, and best of luck! Can't wait to see some photos! This looks like a fun list...
-2021 Venom X22-GT
-2021 Venom X22
-1910 Flying Merkel Board Track Racer Replica (self-built)
IG: @TyGuyProductions
Old 11-17-2021, 01:51 PM   #4
Tundra210   Tundra210 is offline
Hey how's the build going?
