Old 09-05-2021, 09:52 PM   #1
neterno   neterno is offline
Hawk RPS 250 - Throttle Issues
No performance parts on my new Hawk RPS 250.
No real miles (~25) on the bike.
Keihin clone carb.
NGK spark plug.
Idle mixture screw turned out 1.75 turns.
Valves set to .05mm
Air filter clean.
Idles good with K40 pilot jet. Throttle good up to about 1/4 turn.
Wide open throttle results in sudden power drop, chugging, some black smoke out of exhaust, and dies.
Between 1/4 and 3/4 throttle, loses power, no acceleration, but stays running.
These scenarios occur, without any difference, with all of the following main jets: K120, K125, K130, and K140. Needle is at notch 2.
Located outside Chicago - Roughly 800 feet above sea level.
Last edited by neterno; 09-05-2021 at 10:21 PM. Reason: Unsure about Keihin to Mikuni conversion
Old 09-05-2021, 09:56 PM   #2
Main is too big. Drop to a 105, or at most a 110. Set needle back to 3rd slot.
Old 09-05-2021, 10:14 PM   #3
I tried a K120 with the needle at notch 3.
And I tried a K125 with the needle at notch 3.
Still same results.
Old 09-05-2021, 11:48 PM   #4
Still same results.
So, you went from Too big to even bigger and it still ran rich? ...Think about what I said previously and apply it. Main jet is too big. Install a 105,, set needle to third notch.
Old 09-07-2021, 05:42 PM   #5
krat   krat is offline
Got to agree, you need less fuel or more air. With no mods to intake or exhaust 95-105 should be right.
Mine came with an 88 stock and barely pulled itself down the road.
Mine will now run with a 120 but it has a cone filter and a punched exhaust and gutted cat. It still popped and backfired so badly I dropped back to a 110 and it smoothed out.
%90 of the Chinese motorbikes ever made are still on the road. The other %10 made it back home.
