Old 08-14-2021, 06:22 PM   #1
LP   LP is offline
Angry Hawk DLX throttle has a mind of its own.
Bike was surging under throttle, held revs with clutch lever pulled between shifts,
had an extremely high idle
Finally threw CEL, code p0123, TPS
Got new throttle body with sensors from PowersportsMax under warranty (bikes at only 1600 miles)
Installed new battery and throttle body
Starts strong, CEL is gone, idles from 1500-2000, but breaks up under throttle and will stall when rolling to a stop.
Que pasa? I just wanna ride guys!
Old 08-21-2021, 07:15 PM   #2
mototech77   mototech77 is offline
mototech77's Avatar
HVe you checked the valve lash?
Old 04-11-2022, 01:27 PM   #3
Ftpdaplug   Ftpdaplug is offline
do you know and aftermarket cable for hawk 250 dlx throttle cable
Old 04-11-2022, 01:32 PM   #4
You may need to give it time for the ECU to relearn the new TPS.
2004 Honda ST 1300
Old 04-12-2022, 05:22 PM   #5
hawkventure   hawkventure is offline
I hate the stock throttle. I just posted in another thread about replacing the whole throttle assembly cables and barrel adjuster with aftermarket stuff that I found to be easier for me to work with/troubleshoot here https://www.chinariders.net/showthread.php?t=30665. My issue was broken plastic in the grip and the mechanics of the cable tension not working right though. So before buying parts I would disconnect the cable and test manually in neutral to make sure its not something electrical related to the efi.
hawk dlx
