Old 08-06-2021, 04:22 PM   #1
alex_in_az   alex_in_az is offline
engine not charging
for some reason my engine is not charging the battery, where should I start on trouble shooting? I had a voltmeter hooked to the battery and see no increase in voltage when I start and rev the engine
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
Old 08-06-2021, 05:26 PM   #2
stewbrash's Avatar
Check your regulator/rectifier and connections going to it. Also there is a yellow and white wire coming out of your stator...these are ac and they are going to your regulator...mine reads 20 volts ac when it is running. Coming out of the regulator, it reads 13.2 volts dc at idle and ~14 at higher RPM's.
Old 08-06-2021, 06:18 PM   #3
I found this, great study on Rectifier/Regulator.
Old 08-06-2021, 11:05 PM   #4
jmich   jmich is offline
http://www.chinariders.net/showthread.php?t=29014
Old 08-07-2021, 01:29 PM   #5
Originally Posted by jmich View Post
thanks Bro
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
290 degree cam
Front fork brace
Old 08-07-2021, 05:49 PM   #6
Hopefully that will fix it!
