Old 07-21-2021, 09:15 PM   #1
Concealpro   Concealpro is offline
Bought a project
After looking and looking for a decent priced adult size go kart, my kids are tall, we opted for the project machine. No idea of the year, but it's a Hammerhead 200. The engine runs, that's about it. It's definitely not the original. It's a GY6 that's all I know. It has a kick start also. My question is can I take the kickstart off? What parts do i need to delete that? I also have the clutch in the floorboard. Any links to where I can buy the correct clutch parts, forward and reverse. The guy I bought it from also said something about the shaft being too long. Our plan is to completely strip this down, replace everything needed, upgrade the engine parts and repaint. Thanks for any input.
Old 07-21-2021, 09:50 PM   #2
Current clutch, not sure what's going on here
Old 07-22-2021, 09:34 AM   #3
A little better resizing
Old 07-29-2021, 11:18 AM   #4
Project seems to be an understatement. I can't seem to find out any info on the reverse gear box I have and after starting to tear down the engine, the GY6 output shaft is smaller than the output shaft that came with the reverse i have. There is also an issue with the axle sprocket location. If I buy a new output shaft and new reverse gear, the sprockets will be several inches off. Apparently the Hammerhead GT200s had internal reverse in the case.
Old 09-01-2021, 05:12 PM   #5
dugndeep   dugndeep is offline
Wish I could help you but I just got done putting a kick start on a Tao Bull 200 atv.It's got a CVT transmission similar to yours with F-N-R.I have a lever to shift mine into F-N-R,how does yours shift?Cable?
Old 09-01-2021, 05:17 PM   #6
Doesn't Polaris own Hammerhead?Why does it have a clutch on the outside?
Old 09-01-2021, 05:22 PM   #7
That doesn't look like the right motor that it come with new?
Old 09-01-2021, 05:29 PM   #8
https://www.hammerheadoffroad.com/
