Go Back   ChinaRiders Forums > General > News, Support, & Feedback
Old 07-20-2021, 12:37 AM   #1
1stTimeDirt   1stTimeDirt is offline
Noob looking for help
Does anyone know where I can find information or parts for a 2005 terminator 150gy? I don't even know what kind of oil or oil filter it needs
Old 07-20-2021, 02:18 AM   #2
franque   franque is offline
It appears to be a copy of a Honda CG125... if that's the case, 10w-40 is fine for it, and there isn't an oil filter in particular. There is an oil slinger that can be cleaned under the right side cover, which must be removed. Inside you'll find a cover that appears to have Phillips head screws on it. They aren't Phillips head, they're a head called JIS.
They look the same, but Phillps heads are designed to cam out with excessive torque, JIS are not, so what will happen is that you'll not be able to remove the screws with a standard Phillips screwdriver, you'll ruin the screws instead and not be able to remove the cover.
To save you the trouble, get a proper JIS #2 screwdriver: https://www.amazon.com/Vessel-Megado...dp/B000TG8OTY/
Old 07-20-2021, 05:35 AM   #3
Mudflap   Mudflap is offline
Do a Google search for a Honda CG125 factory service manual. Everything except a few measurements will be the same.
