Old 06-21-2021, 08:32 PM   #1
jimbojonesn   jimbojonesn is offline
Help me identify my make and model?
I have good running 125cc shaft-drive, and have no idea what the make and model of the motor is. My problem is that it leaks oil quite a bit from the case
(I think) and I want to be sure of which gasket kit to get, or if it's not worth it at all, and I should just buy a new motor? Reverse is also broken somehow.
Old 06-23-2021, 07:35 AM   #2
dugndeep   dugndeep is offline
I seen this somewhere-152 is 125 cc horizontal engine (Honda Cub type)
Old 06-23-2021, 08:31 AM   #3
I would definitely want to have reverse,but that could just be a $10? gear.Since your having to tear the engine apart to to replace the case gasket???
But if you deem the 4 wheeler worthy of a new engine,you could go that route.???
Old 06-23-2021, 11:18 AM   #4
According to Human Being (an expert here), the ATV was manufactured by Dajiang Motor. Reading the rest of the code says that it's a 110cc.
As for replacing the motor, a drive shaft one is going to be hard to find as most, if not all, replacement motors have sprockets. Converting over to chain driven will involve replacing everything rear of the motor.
IMO, best bet is repair as suggested by dugndeep.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 06-23-2021, 01:27 PM   #5
Thanks all, I think my reverse is just broken from the outside, there's some kind of cable attached to the motor that is broken.
Guess I will get a couple gasket kits and go to town! Does anyone know where I could find some torque specs when I put this back together?
Old 06-23-2021, 03:54 PM   #6
franque   franque is offline
Just find a CT 110 manual online and the specs should be close enough.
