Old 05-28-2021, 01:01 PM   #1
Ianprib   Ianprib is offline
Doh! Apollo 250 Lost compression
So I just changed the oil at 300 miles and after doing so I started it and it started just fine. I let it warm up and then hopped on to see how it ran with fresh oil. After 10 seconds it shut off and began to click in the motor. I tore it down and opened the valve covers to see that the exhaust valve was opening a 1/4 inch. After tightening it back down I still have very low compression. Any suggestions on what I can try and does anyone have any links for a gasket set for it. The full name is the Apollo DB-36 250RX
Old 05-28-2021, 04:38 PM   #2
cycleway4   cycleway4 is offline
sorry to hear of the issue you're having....probably for better help here on the forum,..we may need clarification on what you mean "exhaust valve was opening a 1/4 inch. After tightening it back down...."
<div>Steve
2006 Roketa DB-07A/RSX-200E
2008 Roketa 250 Scooter
2019 Brozz 250
Old 05-28-2021, 05:25 PM   #3
DSM   DSM is offline
1/4” gap I suspect.
Sounds like it ingested something. Pull the plug and have a look inside.
Old 05-28-2021, 05:54 PM   #4
Does that use the CB style (OHC) engine, or our CG (OHV) engine?
2021 Tao Tbr7 - "Lucille"
2009 Q-link Legacy 250
