Old 05-27-2021, 09:54 PM   #1
Dustin   Dustin is offline
HELP! BSR Raven No Power !
Not sure if I should post this here . I bought and assembled my BSR Raven. Charged the battery, turned the key , lights on the dash and hit the ignition button. Fired up first try.
Well I was on my third heat cycle . Putted around the yard , just enjoying the crap out of the bike.
Went to start it again, no lights on the cluster when I turn the key, not starting when I hit the electric start. Possible bad ignition? Fuse is good. Checked all wires behind the light. No lights work, bike is dead lol.
I have lights , cluster works when I kick start the bike. Runs really well actually after a fresh oil change.
Any help is appreciated!
Old 05-27-2021, 10:25 PM   #2
krat   krat is offline
Check your other thread up top.
%90 of the Chinese motorbikes ever made are still on the road. The other %10 made it back home.
Old 05-28-2021, 03:01 AM   #3
stewbrash's Avatar
It sounds like either a bad connection from the battery or a bad battery. Have you taken a reading with a voltmeter...you should get around 12.5 volts...not running...and 13+ running.
bsr raven, electrical issue, ignition
