Old 05-27-2021, 11:07 AM   #1
ChopperCharles   ChopperCharles is offline
ChopperCharles's Avatar
Broken shock bushing!?
Found the source of my suspension's "squeaka-squeaka" noise. Plenty of grease, it wasn't seized, it appears to be poor metallurgy :(
Looks like I have to replace the entire linkage to get just this part. For now, I welded it back together and then turned it back down to round with my metal lathe. I'll order some bar stock and turn a new one after my upcoming trip.
Charles.
Old 06-01-2021, 05:47 PM   #2
Lukas   Lukas is offline
Hey charlie, I noticed some slack in my suspension,I searched the forums and wrote to change
the grease every season, preferably Bel Ray Waterproof Grease. cjines want 75$ for complet rear susension.
https://pl.aliexpress.com/item/10050...3d073e5fsOnIqI
Old 06-07-2021, 05:48 PM   #3
With shipping that's actually more expensive than ordering it from CSC.
Charles.
Old 07-19-2021, 04:34 PM   #4
So, as it turns out CSC *does* sell the parts to rebuild the linkage. The pics are not on the microfiche, but the part numbers are:
Z65-104 REAR SUBASSEMBLY BUSH, ROCKING FRAME II
Z65-115 NEEDLE BEARING HK2020
Total was under $14 including shipping. (Parts were under $7, shipping was just over $7)
I re-used my rubber seals because they came out without any damage.
Charles.
Old 08-01-2021, 04:29 PM   #5
Sullybiker's Avatar
Charles.
This is a great example of the CSC model working the way it's supposed to. If you get in touch they can usually fix you up with most bits and pieces.
Old 10-18-2021, 02:38 AM   #6
SGCSCRX3   SGCSCRX3 is offline
I did check my bolts for tightness today for that lower shock mount area. I had to snug them up as they were a bit on the loose side.
Old 10-18-2021, 04:06 AM   #7
And to add I did pull this all apart and cleanup and regrease those bearings. All looked ok I'm sure I put too much grease back in lol and also torqued to spec.
