Old 05-25-2021, 08:06 AM   #1
MOBTao   MOBTao is offline
Tbr7 needs a Tach
Well maybe needs is a bit much, I guess more i would like to add one to the bike. Does anyone have a simple add on Tach or something that they can recommend?
Thanks in advance.
Old 05-25-2021, 08:32 AM   #2
Mudflap   Mudflap is offline
The little digital tach/hour meters work well and are super cheap and easy to install. The disadvantage is that they have a small display and aren't quick to update.
Old 05-25-2021, 12:54 PM   #3
idle_purr   idle_purr is offline
idle_purr's Avatar
https://www.amazon.com/RacingPowerSp.../dp/B07931P2P1
NO HILL TOO STEEP NO MUD TOO DEEP
The Brozz | The Hawk Upgrades, Accessories, Etc...
Assembly Checklist: Brozz 250 | Hawk 250
~idle_purr
Old 05-25-2021, 08:11 PM   #4
dhilbish   dhilbish is offline
Digital Tach
It took a bunch of wiring work but I installed this digital instrument cluster. I am really happy with it and can offer guidance on how to install one. I even have a template to create the mounting bracket.
You can also see the phone charger/voltmeter/temperature and tire pressure gauge in the photo. For $110 I got the same digital data as a KTM or BMW provides. These photos were taken during the install the final is very buttoned up.
Old 05-26-2021, 12:24 AM   #5
Right on thank you guys!
Old 05-26-2021, 04:41 AM   #6
Do you think that cluster will fit behind the stock headlight plastic?
Old 05-26-2021, 05:50 AM   #7
It does fit behind the stock headlight. I will grab a photo of mine. It is tight but actually looks pretty good.
Old 05-27-2021, 12:18 AM   #8
Ok cool thank you for the help and info.
Old 06-03-2021, 10:10 AM   #9
Final Digital Cluster
Here are the photos of my final installation of a new digital cluster. I managed the digital cluster, a tire pressure sensor, voltmeter and USB charger for $110.
I am setting the bike up for a long distance ride in Africa.
Old 06-03-2021, 10:51 AM   #10
alex_in_az   alex_in_az is online now
that's an awesone setup you've got there! where did you get the wind shield from? also how is the tire pressure display mounted?
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
Old 06-03-2021, 12:45 PM   #11
stewbrash's Avatar
Since the cool digital gauges from Matt are unobtanium or getting eBay's overpriced ($95) unit, does it come with a somewhat understandable instruction booklet? I'd also like to see what it looks like with the headlight attached?
Old 06-03-2021, 01:24 PM   #12
bogieboy's Avatar
i am wondering if you can set your odometer with this dash? i am looking to replace a failing Trailtech vector, and in NY i need to have accurate odometer for inspection....
Old 06-03-2021, 08:44 PM   #13
The windshield is from Amazon. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1.
The tire pressure guage is mounted with a simple bolt on the custom bracket I had to make for the Tach/Spedo
Old 06-03-2021, 08:56 PM   #14
The odometer is configurable.
Old 06-03-2021, 08:56 PM   #15
I have a cool guage from Matt for sale if anyone wants ones.
