Old 05-19-2021, 04:34 PM   #1
Ianprib   Ianprib is offline
Question Apollo DB-36 Bogging
Ive had the Apollo db-36 250 for about 6 months now and since the weather has changed from cold to warm, it boggs and jumps at anything past 1/4 throttle. Ive tried changing the carb to a nibbi, changing the jets, changing the needle position and repositioning the air screw. Nothing has had really any effect on it. Is there anything other than the carb that could be causing this?
Old 05-19-2021, 05:07 PM   #2
Might check valve lash... that's the 1st thing that we'll tell you.
But you might check for a crack or leak in the intake manifold.
2021 Tao Tbr7 - "Lucille"
2009 Q-link Legacy 250
Old 05-20-2021, 04:50 AM   #3
Its_not_a_honda   Its_not_a_honda is offline
Easy things first. Spark plug. Non ethanol gas. Valve lash.
2020 Kawasaki KLX300R, 2018 Yamaha TW200
If you want more of something, tax it less. If you want less of something, tax it more.
Old 05-20-2021, 05:36 AM   #4
I hadn't thought of the spark plug, they are of dubious quality from China. Good call.
apollo 250, enduro
