Lifan X-Pect Fork Oil
Anyone on here have experience with changing out the fork oil on one of these? I’ve done a little research on changing the oil viscosity to help tighten up the ride a bit. One guy recommended going up to 15w or 20w for this bike, but I don’t know what comes in them from the factory, so I don’t know if I want to go that heavy (if it comes with 5w, maybe stepping up to 10 might be better?)
I do mostly street riding and I weigh 165 lbs |
#2 | |
15W in a Magician
Try 10w, and if it is still too soft. Try 15. The key is to stick to the same brand of oil as there is no national standard for viscosity, so one companies 10wt might be similar to anothers 15 or 5 wt. I like pj1 fork oil myself, but there are plenty of others put there.
Thanks
Thanks @piglife and @megadan for the responses!
Nobody does, including the factory - LOL I went with Motul 15w for my Hawk but I'm 230lbs.
2020 RPS Hawk 250 - Build thread can be found here: http://www.chinariders.net/showthread.php?t=28374 "Do Wheelies and Forget your Feelies" "If vegetarians eat vegetables, what do humanitarians eat?" -unknown |
Level can have a big effect on "stiffness". Before changing out all that fluid, get a cheap baster, and try drawing out or adding about 1/2" in each tube and see if it gets better. It's real easy but can make a little mess.
If it doesn't help, then go ahead and switch to another oil.
2021 Tao Tbr7 - "Lucille" Mods so far- Brozz swingarm, 21" front rim (Bridgestone Tw302 rear/Dunlop D606 front tires), Digital gauge cluster, pz30b pumper carb, after market hand guards, aftermarket brake and clutch levers, round fold away mirrors, Fly handlebars shortened slightly, 13t front sprocket 2009 Q-link Legacy 250 1982 Suzuki GS1100ES - "Jolene" Last edited by TxTaoRider; 05-13-2021 at 03:32 PM. |
Tags |
fork oil, xpect |
