Old 05-10-2021, 12:57 PM   #1
LD2021   LD2021 is offline
Tao Tao Starting Issues
Hi - new to this site, but I have reached the end of my wits.
Have a Tao Tao ATA 125 for my kids, and it would not start.
1. New Battery installed- full charge, per multi meter
2. Tested Solenoid- good, see below.
3. Multi Meter shows power from battery to Sol and from other post to starter motor. No resistance in between sol posts- all good.
4 The starter was removed and jumped tested off the machine- works.
5. Back on the machine, the starter will just not activate. Just hear solenoid clicking.
Here's what I think. I found that the ground wire to the starter is badly crimped at the starter terminal (the copper connector).
Could this be a grounding issue? It's the only thing left I can think of...any help appreciated!!
Old 05-10-2021, 01:26 PM   #2
Oldenslow   Oldenslow is offline
Certainly could be. I'm just about convinced after decades of fussing with non-starting machines that "bad ground" is the cause of many, many, many weird problems...
Old 05-10-2021, 03:56 PM   #3
CheapThrills   CheapThrills is offline
Not sure if it's the same, but on my TBR7, I had a problem with the clutch switch. Pretty flimsy and taught me to only start with gear in Neutral.
Not familiar with AT 125, does it have this type of cutout?
- My 2 Bikes:
TaoTao TBR7
Boom Vader Gen 2 (BD125-10)
Testing a YouTube Channel
Old 05-10-2021, 07:41 PM   #4
Not sure, but thanks...I will check!
Old 05-10-2021, 09:28 PM   #5
Piglife   Piglife is offline
It's the ground
I bet it's your ground-a bad ground causes a drop in amps meaning that you won't have the need power to spin the starter. Replace the lug on your ground and make cure its a good connection.
I hope this works and good luck.
Old 05-11-2021, 01:35 PM   #6
dirtbkr188   dirtbkr188 is offline
dirtbkr188's Avatar
Take a screwdriver and "jump" the two big poles on the solenoid, if the starter turns over then there's a real good chance that the solenoid is bad.
Old 05-14-2021, 11:40 AM   #7
rmueller   rmueller is offline
my bull 200 the brake hand switch/safty would not let me start the eng
Old 05-25-2021, 07:44 AM   #8
dugndeep   dugndeep is offline
I never use the handlebar on and off switch and tell anybody that rides it to just use the key to turn it on and off,I hear so many problems associated with the kill switch and that's why I don't ever touch it.
