Old 05-01-2021, 01:47 AM   #1
Skateforlife6   Skateforlife6 is offline
Question TBR7 carb tuning?
So I'm confused as to exactly what parts I need to buy. I just want to tune the stock carb when I get my bike. The only other mod I'll do is the airbox mod. So what will I need to do to the stock carb and where can I find the parts needed? Please try to be specific, I'm already confused. Thanks everyone.
Old 05-01-2021, 09:54 AM   #2
gwowzer   gwowzer is offline
You'll need a dremel with cutoff wheel, or a small hacksaw, a flathead screwdriver, a pilot jet, and a main jet. Jet kits can be found on Amazon. You'll also need one or two tiny brass washers from the hardware store to fit the needle. That should cover it.
Old 05-01-2021, 10:21 AM   #3
What airbox mod are you doing on your TBR7? If it's the one that some do on the hawks, you'll find the tbr7 has a different snorkel thats larger than the hawks and made from rubber.
2021 Tao Tbr7 - "Lucille"
2009 Q-link Legacy 250
Old 05-01-2021, 11:25 AM   #4
alex_in_az   alex_in_az is offline
yup, TBR7 doesn't need the airbox mod
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
Old 05-01-2021, 11:27 AM   #5
Skyd   Skyd is offline
Skyd's Avatar
you may need to shim the needle as well, but a small washer will do the trick
2020 RPS Hawk 250 - Build thread can be found here: http://www.chinariders.net/showthread.php?t=28374
"Do Wheelies and Forget your Feelies"
"If vegetarians eat vegetables, what do humanitarians eat?" -unknown
carb, carbeurator, taotao, tbr7
