Old 04-25-2008, 04:36 PM   #1
skidder   skidder is offline
i'm sure this has been asked before
many times , but i cant find anything on the site! If the lifan 200 is based on a honda motor which motor is it based on obviously a 200 but year and model. Or is it really loosely based on one, I would like to know in order to search oem parts on hondas ??? If it is even possible???
Old 04-25-2008, 05:08 PM   #2
No real connection to Hondas, other than looks. Maybe something, maybe, sort of, maybe..... :x
Old 04-25-2008, 09:06 PM   #3
rigidchop   rigidchop is offline
has to be more than looks if OB1 could put a lifan engine in an xr200 and use the honda wiring harness.
Old 04-25-2008, 09:35 PM   #4
Nothing internally, for the most part. Externally, these things will bolt (with some help in some cases)in to a wide range of older Honda products.
Old 04-26-2008, 01:24 PM   #5
Back_From_The_Dead   Back_From_The_Dead is offline
Correct, and SOME of the parts will work im not sure exactly what ones but I know there are some, someone must know.
Old 04-26-2008, 01:59 PM   #6
Shy   Shy is offline
Hello People
So far I've found the following honda parts fit directly onto my 1996 125 GY engine...
CRF 230 coil
XR 200 Carb
XR/CRF CDI
Still stuck on exhaust but some non standard XR 200 and the CRF 230 look pretty close.
http://www.motocrossworld.com/ have detailed parts drawings if anyone wants to take a look.
Hope that helps.
Old 04-26-2008, 02:49 PM   #7
elroyjetsn   elroyjetsn is offline
Re: i'm sure this has been asked before
Mustang posted this link to the Honda CG125 service manual a while back:
http://imirror.org/files/Honda_CG125...ice_Manual.pdf
As i was going thru it i could see strong similarities to our pushrod engines.
'Cept for a few minor details that is
Wayne
Wildfire WF300-SP
Old 04-26-2008, 04:09 PM   #8
coleary15   coleary15 is offline
Send a message via AIM to coleary15
on my roketa db-27 the whole bike and engine can be replaced with any part off of a 1981 xr100r
Old 04-26-2008, 09:55 PM   #9
pumpkin   pumpkin is offline
i took my starter relay to the honda shop and matched one up. i don't know what model,but it was a stock honda part. i didn't buy it cause it was $70.00.
06 american lifan 200 gy-5
Old 04-26-2008, 11:06 PM   #10
Try a Ford relay. $5 at Autozone.
Old 04-28-2008, 01:56 AM   #11
i tried a ford relay but couldn't get it to work. good thing SamM was parting out his viva at the time.
Old 04-28-2008, 09:10 AM   #12
tcs   tcs is offline
Originally Posted by elroyjetsn
Mustang posted this link to the Honda CG125 service manual a while back...As i was going thru it i could see strong similarities to our pushrod engines.
Honda's small displacement single cylinder OHC (Over Head Cam) engines, like the one in their CB125, had a weakness in their top end lubrication. Honda solved the problem over 30 years ago by designing an OHV (Over Head Valve) version. It doesn't rev quite as high or make quite as much power at the same displacement as the OHC version, but it is smaller, lighter and less expensive to manufacture.
It's a great design with broad appeal even today. Honda reports in their latest finacial results that their CG125 is not only still in production but increasing in worldwide sales.
Fun fact: all of Honda's "utility" line of ATVs have OHV engines.
tcs
