Factory battery initial charge?
Bike just arrived but I won’t be working on it tonight. As far as charging the stock battery after filling. Do you put the caps back in while charging or leave them out like old school?
Thanks in advance! |
Hi, I don't think it matters. I know I left mine in with no issues.
John |
After I filled my battery, I let it sit for an hour before charging. I installed the caps before charging.
2019 Z 400 2020 Tan Recon 2021 KLX 300 2022 GPX FSE 450R |
surprisingly, mine came with a full charge. i didn't have a tender, so i just filled it, let it sit, took it to advance and they said it read fully charged. it worked immediately. mine must have been a fluke
For safety reasons, leave the caps off during the initial charge.
Left the caps off for the first 6 hours at 2 amps. It’s not capped and on a tender/maintenance charge overnight
Thanks for the info everyone. |
The batteries on the Brozz bikes are supposedly shipped pre-charged. You could add the acid let it sit to stabilize and use it to start the bike. My battery showed fully charged in less than 30 minutes on a 1 amp charger.
