Old 03-26-2021, 04:54 AM   #1
DeclaringBeast   DeclaringBeast is offline
Apollo 250 dirt bike
brand new apollo 250 agb looking to upgrade my chain and have no clue what i should be looking for, does anyone have any links or can tell me the exact size chain i need.
Old 03-26-2021, 06:09 AM   #2
Its_not_a_honda   Its_not_a_honda is offline
Mine is a 2017 and it has a 530 chain. Just clean it and oil it. I still have my original chain. It has been through everything you can think of.
2020 Kawasaki KLX300R, 2018 Yamaha TW200
If you want more of something, tax it less. If you want less of something, tax it more.
Old 03-26-2021, 10:11 AM   #3
It seems like i have to tighten it after every ride, is that normal?
Old 03-27-2021, 07:39 AM   #4
Just make sure you are adjusting it properly. Do not tighten it. Adjust it. If you will notice as the suspension compresses, the chain gets tighter as the swing arm gets level with the counter shaft sprocket. There are tons of videos and websites to give proper ways of doing it. I personally use straps to pull the suspension down to where the chain shows the least slack. I then adjust to about 1/2 inch movement up and down. I have to do this because I put on a longer shock and I cannot go by the factory recommendations. Your manual should tell you the specific up and down movement of the chain with the suspension fully extended. That means on a stand or with the kickstand down and shock fully extended.
