Hawk brake upgrade - Just thinking
Hey guys,
So I'm waiting for my hawk to show up, but I'm hyper fixated on it already. HAHA So anyway while poking around the forums, gathering my list of immediate and future upgrades and modifications I got to thinking about brakes. I'm going to flush the system and fill with DOT4 fluid and run it. However, I see alot of squawking particularly about the rear brakes AND I've also seen/heard the pedal isn't very adjustable or comfortable for alot of people. My question is, has anyone tried swapping out the calipers or master cylinder/brake pedal assembly for something better? I actually had this "issue" with my DRZ400. The rear brake was ok, but I swapped it for a CRF450 setup and it made a world of difference. Just wondering if anyone has played around with something like that and what might match up.... I'm a firm believer that you should make your stuff stop better before you make it go faster. Thoughts?
2020 RPS Hawk 250 - Build thread can be found here: http://www.chinariders.net/showthread.php?t=28374 "Do Wheelies and Forget your Feelies" "If vegetarians eat vegetables, what do humanitarians eat?" -unknown |
The Hawk rear brake is just about as powerful as the front. The only real complaint I have is the brake pedal itself not being shaped very well. I just haven't looked into replacing it. Instead, I took it off, heated and reshaped it by straightening it out to make the end further inboard and farther away from the peg. All that required was straightening it quite a bit.
Hawk Information and Resource guide: http://www.chinariders.net/showthread.php?t=20331 2018 Hawk 250 - Full Mod list here. http://www.chinariders.net/showpost....62&postcount=1 2024 Royal Enfield Shotgun 650 https://chinariders.net/showthread.php?t=34124 Last edited by Megadan; 03-19-2021 at 04:56 PM. |
Cleaning the brake rotors real good with brake cleaner to remove the protective oily film we help. Clean them before even riding the bike.
I swapped the brozz rear brake (single piston) onto my tbr7 (which was a dual piston like the hawk) when I did the swingarm conversion. At first it was noticeably weaker, but after it got bedded it works pretty good. I may put a hawk caliper on it later since it's a bolt on.
I just put all new brake components on the 2015 hawk i am rebuilding. I went with a similar master, braided brake lines, new hawk rear caliper (couldn't find a cheap suitable replacement) and they feel really strong in testing.
https://www.ebay.com/itm/USA-Rear-Br...72.m2749.l2649 This caliper is an exact bolt up match to what comes on the hawk and is pretty cheap. Also gets you generic brake pads that are the same as the rear: https://www.ebay.com/itm/Front-Brake...72.m2749.l2649 For when the link dies: "Front Brake Caliper for Suzuki RM125 RM250 RMX250 DR250 DR350 DR250SE DR350SE" |
I'd be more interested in a front brake upgrade.
