Old 03-18-2021, 08:29 PM   #1
Lukas   Lukas is offline
Where is the A1 cable?
Hello, everyone I have a question if anyone knows where is the hidden bridged cable for the A1 light I am changing the light switch from automatic to normal and I have a problem with it.
Old 03-25-2021, 07:55 PM   #2
Ok I found this cable is in the left switch blue and yellow just connect it with the cable from the right switch from the position A1 lights and that's all I unplugged the cable from the switch under the tank and made a new cable using furukawa plugs.I changed the switches for copy of Zontec. Original switch from RX3 does not have a cable to a1, but you can add it and file the lock visible in the picture and you will also be able to turn off the lights completely.I also added plastic from RX3S under speedometer.
Old 03-25-2021, 08:05 PM   #3
more
