04-23-2008, 05:11 PM | #1 |
ngk spark plug...i dont get it
i bought a d8ea but the tech info has one in bold letters...can i still use mine?
04-24-2008, 12:19 AM | #2 |
for what and on what ?
do they match up , thread depth ?
DesertDog |
04-24-2008, 03:41 PM | #3 |
yeah they match up...
04-24-2008, 04:55 PM | #4 | |
Re: ngk spark plug...i dont get it
04-24-2008, 06:40 PM | #5 |
yeah it did in the tech info section but it didnt have it in bold....go check it out....
04-24-2008, 06:57 PM | #6 |
The short answer is....yes, your plug will work. Those in bold are the recommended plugs, and not the only plugs that will work.
The long answer... Plugs are not all equal. Some burn cooler, others hotter. Each engine needs to be tuned for the conditions under which it operates, so one engine may need a hotter plug, while another will need a cooler plug. Everything in the system from the air filter, to the carb jet, to the exhaust...all determine how the engine runs...i.e. lean or rich. Too much fuel or too much air....which is what helps determine what plug is best. Having said that, I really only have a basic understanding of how it all works. I'm sure many others here could offer better advice as to the best plug for you to use in your specific application, but the one you mentioned will fit, and it will work. It may not, however, allow the engine to perform at it's best. That would require more information about your bike and it's current performance. I hope that helps. (And I trust that someone will correct me where I'm wrong! )
2008 American Lifan LF200 GY-5 (930 km) - Sold 2007 Kawasaki EX250 - Sold 2006 Kawasaki EX650R - My new ride! 2005 Kawasaki EX250 - A new project |
04-24-2008, 07:00 PM | #7 |
I see what You are saying now, The dr8ea is just a resistor version of the d8ea....Hope that clears it up.
04-26-2008, 01:17 PM | #8 |
ok i get it i was just majing sure i wasnt gonna blow up my bike with the wrong plug...its prolly not possible doing that but yeah u get my point lol
04-26-2008, 05:08 PM | #9 |
no bike will die before its time
DesertDog |
04-26-2008, 05:16 PM | #10 |
ok good lol
05-18-2008, 09:58 PM | #11 |
NGK=No Good Krap!! I use anything but,been burned too many times by them!!
"If you`re not FIRST,you`re Last!!-Ricky Bobby |
05-19-2008, 11:52 AM | #12 | |
05-20-2008, 01:10 PM | #13 |
Odd how people differ, I have had great luck with NGK and bad luck with Champions :?
05-20-2008, 03:57 PM | #14 | |
IronFist ___________________________________ The "chain" of command is used for beating spammers. ___________________________________ |
05-20-2008, 04:31 PM | #15 |
I run NGK plugs on my 83 chevy blazer. Best ones I've had so far.
2007 VX 250 PR, uni 2 stage air filter, threw the dead battery away and bored the box out for the air filter. Changed out the main jet with a Keihin 100. 2002 CRF450R Replaced the head with an 06 and rebuilt the forks. Mean Mean Machine |
