Old 03-09-2021, 05:52 PM   #1
idle_purr   idle_purr is offline
idle_purr's Avatar
Bee, My Brozz 250
I named my Brozz 250 Bee, and this thread is dedicated to her.
I will randomly update this thread and add it to my siggy
I will post pics and videos of the bike, as well as anything related to my bike. I will also post things that I get specifically for my Bike/Toolkit/Essentials.
Intro Pics:
Intro Videos:
Assembly Checklist & Resources:
View or Print Assembly Checklist
Brozz 250 Torque Specs | Brozz 250 Engine Torque Specs
Brozz 250 Parts Diagram | Brozz 250 Engine Diagrams
brozz250.com
Fluids & Misc...
Loctite Threadlock Blue 242
Permatex 22058 Dielectric Tune-Up Grease
Green Grease 101 Synthetic Waterproof High Temperature Grease
CRC BRAKLEEN Brake Parts Cleaner
Gumout Carb and Choke Cleaner, 14oz
Protect All Cable Life - Cable Lubricator
Maxima 54901 5WT Standard Hydraulic Fork Oil
Valvoline 4-Stroke Motorcycle SAE 20W-50
Dupont Teflon Chain Saver Lubricant
Prestone AS400 DOT 3 Brake Fluid
No-Spill 1405 2-1/2-Gallon Poly Gas Can
Upgrades:
Bike Master Folding Shift Lever
Protaper SE CR High 7/8s Handlebars
Niche 428 X-Ring 128 Link
NGK DR8EIX Iridium IX Spark Plug
XTA7B-BS MMG Lithium Ion Sealed Battery
K&N Engine Air Filter: High Performance, Premium, Washable, Replacement Filter.
so far no carb upgrade...
Accessories:
NOCO GENIUS1 Smart Charger
NOCO GC002 X-Connect M6 Eyelet Terminal
NOCO GC004 X-Connect 10-Foot (3m) Extension Cable
Coleman MadDog GearComfort Ride Seat Protector
Motorcycle Tail Bag/Seat Bag Waterproof Luggage Bag
Roam Universal Premium Bike Phone Mount
Inmozata Waterproof Motorcycle Cover
Padlock Chain 48in Motorcycle Bike Anti-Theft Security Alloy Steel
Gear:
Zoan Synchrony Duo Helmet
ILM Motorcycle Gloves Hard Knuckle Protection
ACG Adventure Motorcycle Jacket
Interceptor Men's Wyatt Tactical Boot
Travel Accessories:
Motorcycle / Dirt Bike Carrier Hauler Hitch Mount Rack
CZC AUTO Hitch Tightener
CURT 21510 Trailer Hitch Pin & Clip
Sunferno Ratchet Straps Tie Down 2500Lbs Break Strength
Toolkit:
WORKPRO 14-inch Tool Bag
AstroAI Digital Multimeter, Voltmeter 1.5v/9v/12v
VESSEL BALL GRIP 1/4" Hex. Bit Interchangeable Screwdriver (JIS)
DEWALT 20V MAX Impact Driver Kit
Impact Grade Socket Wrench Adapter Extension Set
Tonsiki 1/4 Inch Screwdriver w/12pc Tamper Proof Torx Bits (for stock carb)
EPAuto 1/2-inch Drive Click Torque Wrench, 10~150 ft./lb
EPAuto 1/2-Inch Drive Metric Deep Impact 6p Socket Set
1/4 Ratcheting Wrench and Bits Set - 28-Piece, Metric
Hex Key Allen Wrench Set with Ball End - Set of 26
CZC AUTO Small Tire Pressure Gauge
Z-Color 1pcs Chain Breaker Link Splitter Pin Remover
Core Tools CT122 Spoon Type Tire Iron, (Pack of 3)
Acarte Carburetor Carbon Dirt Jet Cleaner Tool Kit 10
Stainless Steel Feeler Gauge Universal Standard SAE and Metric
ABN Snap Ring Pliers Set
BikeMaster Spoke Wrench 14-04
GTSpeed Universal Motorcycle Dual Cable Oiler Lubricator Lubing Tool
I also have a higher quality version of the toolset that came with the bike,
and the oddballs that were missing.
NO HILL TOO STEEP NO MUD TOO DEEP
The Brozz | The Hawk Upgrades, Accessories, Etc...
Assembly Checklist: Brozz 250 | Hawk 250
~idle_purr
Old 03-22-2021, 03:41 PM   #2
idle_purr's Avatar
Tailbag and Seat Pad
~idle_purr
Old 03-22-2021, 06:05 PM   #3
Bill Hilly   Bill Hilly is offline
I see you got yourself a tailbag. I ordered one from Amazon, and they never did get around to shipping it, so I cancelled the order, and ordered a trunk from eBay.. I have been looking for any reason to ride mine. I went to town today, for no other reason than to buy a box of garbage bags, which barely fit in the small bag I have rigged on my bike.
Old 03-25-2021, 05:51 PM   #4
idle_purr's Avatar
Custom Keytag
Added my last name to my bike with this custom keytag.
It says WEBB on both sides and came with 2 keytags.
Available Here
~idle_purr
Old 03-29-2021, 10:28 PM   #5
Afan   Afan is offline
Old 04-02-2021, 01:33 PM   #6
idle_purr's Avatar
Recent Mods:
Disabled Hazard Lights
Replaced Starter/Hazard Switch with Starter/Kill Switch
Removed Alarm/Remote Start.
~idle_purr
Old 04-02-2021, 09:16 PM   #7
I may be mis- understanding you. But if you removed the hazzard lights themselves ,then you will have no turn signals.
Old 04-03-2021, 10:33 AM   #8
idle_purr's Avatar
I guess the correct term would be that I disabled them, I did so by removing the light blue wire, the gray wire, and the orange wire coming from the switch that run to the molex plug in the wiring harness.
The physical lights are still there
Signals are working great.
~idle_purr
Old 04-03-2021, 04:59 PM   #9
idle_purr's Avatar
Thumbs Up Some Family Pictures
Sisters!
The Brozz is now Insured and Registered in NY.
~idle_purr
Old 04-10-2021, 02:44 PM   #10
idle_purr's Avatar
My Brozz & Her Cousin
All tagged and inspected!
Got my first road to trail ride in today!
~idle_purr
Old 04-11-2021, 12:03 PM   #11
Have fun on the maiden voyage! I wish those were legal here.
Old 05-04-2021, 03:37 PM   #12
idle_purr's Avatar
Added some brush guards
~idle_purr
Old 05-04-2021, 05:06 PM   #13
Oltzer   Oltzer is offline
Very nice, how did you get them to fit? I ordered some that JFG that look like yours but were no where near fitting. I have some Tusk bars on mine though.
2020 Brozz 250
Old 05-04-2021, 05:12 PM   #14
idle_purr's Avatar
Thank you Oltzer
I had to cut the ball off of the end of my clutch lever but I filed it down and made it look nice. Other than that everything just fit, I assembled it all loosely and then got them where I liked them and clamped them down.
~idle_purr
Old 05-05-2021, 06:04 PM   #15
You can also put some shorty levers on that give you some clearance on the end.
bashan, brozz 250, peace sports
