Old 03-06-2021, 04:32 PM   #1
Ryanwagner100@cs   Ryanwagner100@cs is offline
2017 Hawk 250 Gas tank leak
I took my Hawk out for a ride today, it was a nice ride. But when I got home and turned the fuel petcock valve off I noticed gas dripping from the output of the gas tank. It's just above where the petcock valve is.
Anybody have this issue? I'm guessing a little RTV will fix it? Do I need to drain the tank and seal it from the inside?
I tried to attach a picture but it was to big of a file.
Old 03-06-2021, 04:49 PM   #2
If not the petcock I would look at this link.
http://www.chinariders.net/showthrea...ight=tank+leak
Old 03-06-2021, 05:26 PM   #3
Thank you so much! I'll look into it ASAP!
Old 03-06-2021, 07:04 PM   #4
Bird Fish   Bird Fish is offline
Bird Fish's Avatar
I just fixed mine 2 weeks ago. It's a bad weld or solder job where the petcock stem enters the tank. I cleaned with rubbing alcohol and sealed with JB steel. Holding up so far.
2017 RPS Hawk - 15/50. Rear Foot peg delete. Horn Delete. Tank Bag. Airbox mod. NGK Plug. MSR Shifter. VM26 carb Jetted 120/17.5, middle clip, 1-1/2 turns.
Old 08-27-2021, 09:17 PM   #5
Badluck   Badluck is offline
Mine has the same problem. Is it still holding up?
Old 08-29-2021, 12:13 PM   #6
raven250   raven250 is offline
They don't weld these things correctly from the factory. You can mess around with JB weld like I tried to, but ultimately nothing worked 100%. Don't even bother using epoxy putty, that stuff is not nearly strong enough to contain a leak.
What I ended up doing was buying a Brozz 250 tank and key kit (you need it for the lid) and replacing the whole thing. The tank is ~$60 and the key kit is about the same, so ~$120 total. It's not a perfect fit, but the new style tank has a much better weld pattern without the plate on the bottom which makes the original tank nearly impossible to repair.
IMO the tank is a major safety problem on these bikes and I would never recommend anyone buy a chinese bike after mine blew open.
gas leak, gas tank
