Old 03-02-2021, 11:46 PM   #1
oenvii   oenvii is offline
New here and need help finding a specific sprocket
Hello all,
I purchased a 2020 Bashan Enforcer last fall. Absolutely love it. I'm in the process of the sprocket upgrade and am having issues finding the proper rear for a 428 pitch 45t. My sprocket is offset and I have only found one that is similar. The issue is mine is a 4 pin connector, theirs is 6. I was hoping someone here would know what I could do.
This is the sprocket I could buy but has a 6 pin connection:https://www.ebay.com/itm/35326262729...m=353262627290
Any tips would be great. Thanks!
Also, I've tried a standard sprocket. Does not line up with the front if it's not offset.
Attached is a pic of my current sprocket.
Old 03-03-2021, 06:52 PM   #2
Falkon45   Falkon45 is offline
Falkon45's Avatar
Welcome!!! I'm not really sure about if it fits your bike. If you look around for your factory sprocket, I'm sure you can find the original measurements. I will say this though... You've helped me find a possible sprocket for the KPM 200
Old 03-03-2021, 07:21 PM   #3
Is there enough thread on the studs to use thick washers?
2021 Tao Tbr7 - "Lucille"
2009 Q-link Legacy 250
Old 03-04-2021, 10:26 AM   #4
Falkon45's Avatar
Originally Posted by oenvii View Post
Hello all,
Actually, I've read your post again. No, would will not be able to use a 6 bolt sprocket on the 4 bolt sprocket.
Last edited by Falkon45; 03-10-2021 at 07:55 AM. Reason: Had to delete the sprocket link. It was incorrect
parts
