Old 02-05-2021, 07:07 PM   #1
Rickeyradfo   Rickeyradfo is offline
2021 CSC TT250 fix for sputtering under acceration above 4k
Hi I am new owner of 2021 CSC TT250 & new to forum
While putting break- in miles noted bikes would run fine below 5k rpm..bike would start sputtering under acceration above 5500 rpm. Returned home & noted fuel line from tank to carb was long & routed from tank was route down then up over harness down to carb. I disconnect fuel line & cut 3 inches from line. Repositioned line with a direct path to carb. Now bike does not stutter & pulls up to 8k with no problem. Bike only has 100 miles on it & i saw this fix in another forum.apologies if this should have been posted in another area.
Good luck & love this forum's feedback
Old 02-09-2021, 01:45 AM   #2
TheChairman   TheChairman is offline
I had the identical problem and identical fix on my 2020.
I cleared up all problems once I rejetted.
Old 02-09-2021, 09:56 PM   #3
motochutuya   motochutuya is offline
thanks for posting I noticed this too !
