Quietest muffler for hawk 250
So I got a crf230f exhaust system with no cat but it's loud as hell and the neighbors are probably a bit pissed, what's the quietest muffler for this thing? Preferably that doesn't break the bank or impact performance or jetting much.
P.s. technically a "shark 250" but I'm fairly certain it's the same damn thing.
This is what I got btw
https://www.amazon.com/Exhaust-Muffl.../dp/B01DO6IBLQ |
That's the same exhaust I have.. I guess one man's loud as hell is another's music to my ears as the stock Brozz is embarrassingly quiet
Ya I mean is there a slip on one that's super quiet tho? I mean it sounds great but I don't need noise violations, the pigs around here are real c*ck suckers. Neighbors alreadade some snide comment. Tried to harass me for off-road tires until I just said "their shinko model 244's and dot certified, am I under arrest or free to go?"
Could you possibly try a DIY muffler repack/baffle install on the current muffler you have?
I think I may have read something about a universal db killer that might work with this exhaust but you may want to research that further unless other posters have more info
You might look around for a used crf230f stock exhaust.
I've got a t-4 FMF on mine and it's not very loud.
I have basically the same exhaust. I took the Brozz camping over the summer and that was sort of the final straw for me. It is definitely way louder than what is desirable for me. I don't need everyone in a 2 mile radius knowing I'm out for an evening cruise.
One of the biggest regrets I have with the Brozz is switching the exhaust out. I should have looked harder into doing just a cat delete, and removing the stock exhaust and painting black with a good muffler paint. That being said, I do much prefer the looks of the aftermarket exhaust vs the stock exhaust with the cheesy heat shields and everything. So here is what I did: I ordered a DB killer/baffle, fiberglass muffler packing, and metal zip ties off Amazon. It is a total pain in the ass trying to find a baffle that will fit the common exhaust we use. I ended up finding one that is about 10 mm shy of the ID of the aftermarket exhaust. It came with a bolt and nut and a predrilled hole in the side. I took the bolt and nut off, and threw them in the dumpster. I found a metal tap that would tap threads into the predrilled hole. It ended up being a 5/16 tap. So I threaded the hole, and then I drilled another hole opposite of it and threaded it as well. Then I found stainless bolts at the hardware store to fit the threads I tapped. I wrapped the baffle in the fiberglass packing, cut to size, and secured with the steel zip ties. I left a little extra packing at the end just under the bolts to seal the little bit of gap left at the outlet. Cut the ends off the zip ties, slid her in the exhaust (after taking the exhaust tip off that secures with three allen head bolts), and tightened my bolts up to hold in place. Installed the exhaust tip back on. I'm hoping it adds a little restriction to the exhaust, and that it quiets it down at least a little bit. I haven't fired the bike up yet, as I have it completely disassembled at the moment doing all kinds of other stuff to it over the winter. But I'm hoping it works out ok, and gets the bike to be in a good range of added power, but takes it out of the nuisance zone. |
#10 | |
With a former chopper i had with loud exhaust i read about using stainless steel wool as muffler packing, i tried it and it did help in that application, not sure if it could be packed into this exhaust or not
#11 | ||
I only install it on US Forest areas when I need both more quiet and a USFS spark arrestor in case stopped. |
#12 |
When you say stock spark arrestor, did you take the stock exhaust apart and remove it from there to re-use with modification in the Ebay exhaust?
or is it an aftermarket spark arrestor? thanks
#13 |
Does anyone have a link to a spark arrestor that will fit on the aftermarket one? Or just a 38mm quiet muffler? I uhh, really thought someone would have made a quiet 38mm muffler by now u know man, lol.
#14 | |
https://radpaul.weebly.com/brozz-and-hawk-250.html
#15 | |
