Old 01-31-2021, 09:16 AM   #1
old_airhead   old_airhead is offline
2020 Hawk DLX Wiring Diagram?
Has anyone found a decent wiring diagram for the Hawk DLX? I'm not having any electrical problems, but am curious. Also, I like to check out the diagrams for my bikes (I know, that's a little weird). There are a couple of diagrams in the owner's manual, including a separate one for the ECU, but the smaller text on them is unreadable, even with a magnifying glass. All of the others I've found online seem to be copies of these.
Also, is there no 'Check Engine' light on the DLX? One doesn't show up then the key is turned on. It seems that with more electronics that there should be some kind of indication of ECU problems.
Old 01-31-2021, 04:16 PM   #2
f15sim   f15sim is offline
f15sim's Avatar
There is a CI light on the DLX.
g.
Proud owner of 80-0007.
https://www.f15sim.com - The only one of its kind.
Old 02-01-2021, 08:53 AM   #3
F15sim, thanks. With all of my other vehicles all of the instrument lights turn on when the ignition is initially turned on - probably just to test the light bulbs.
Old 02-01-2021, 10:23 AM   #4
f15sim's Avatar
It's odd that it didn't come on briefly when you turned on the key. I'm not in a position to check mine right now, but someone else should be. *fingers crossed*
g.
