Old 01-23-2021, 11:21 PM   #1
PleaseW84myRX8   PleaseW84myRX8 is offline
TaoTao DB10 won't start
Had nothing but issues from day 1. Had issues starting. Replaced solenoid and starter and it would start again. Ran twice. Now it won't start.
I couldn't get a spark going from the ignition coil. Pulled the gas tank and found a wire was loose in the connector from the harness to the solenoid. Replaced it and still no spark.
Both the solenoid and the starter was new months ago with only 2 rides under its belt. Could they have gone bad already? Either?
If so, could someone recommend me to an upgraded part of both? One that won't fail after 2 rides?
