Old 01-11-2021, 01:37 PM   #1
NinjaSICKthirtysix   NinjaSICKthirtysix is offline
Exclamation Need chain slack figures for hawk, brozz, tbr7, all chinese bikes. Post yours.
Hey all, I am working on something that will benefit all of us. But I need the chain slack number for all the usual chinese bikes, not just enduro.
Hawk, Brozz, TBR7, Magician, SG250 etc
For example, the TT250 is 15mm from mid point.
Old 01-11-2021, 01:42 PM   #2
Brozz: 10-20mm specified range
2024 Zuma Storm 150 DLX
2019 Beta 430 RRS
Former China Bikes: Tao DBX1, Brozz 250, CSC RX4, Titan DLX, Templar X
Old 01-11-2021, 02:54 PM   #3
A HUGE thing to keep in mind with the TT250 measurement is that it is 15mm of free play from the tightest point of the chain WITH the suspension compressed to the tightest point of the chain in the swing arm arc. NOT with the swing arm fully extended down while it is in the air or on a stand.
That method also works for the Hawks, but I have found that at full extension about 1 1/8" slack on the tightest spot of the chain worked best.
This has to do with the rear suspension geometry in relation to the front sprocket. As the rear swing arm travels upward the distance between the sprocket center and axle center increases, thus making the chain tighter.
Old 01-12-2021, 08:39 AM   #4
Mudflap   Mudflap is offline
Megadan is correct. Almost every chain drive bike is the same. 10mm to 20mm movement at the tightest point.
