12-20-2020, 02:56 PM | #1 |
2000 mile update Bashan Storm bought 3-2020
Haven't posted in long time, just sneak in from time to time to see if anyone brought over some bigger bikes yet, tax season around the corner. In meantime still enjoying the ups and downs of my Storm. Reached 2000 mile mark. So far Speedo cable quit (at 200 miles) bought digital cluster but haven't installed yet. Work and car blew up so bike is only ride at moment. Throttle cable snapped couple of weeks ago. 24 hours later Amazon put one on my steps on a Sunday. Installed Moose racing chain, jets (still trying to hone in that sweet spot) NGK Iridium plug, adjust valves, oil changes. Bought 125ml oil cooler- haven't installed yet. Still waiting on headlight bulb. Low beam blew quickly. Did receive 5 really cheap ones from Amazon. Looks like I hold up a candle at night time ride home from work. Can't think of anything else at moment. Plan on removing cat so it can breathe.
12-20-2020, 03:06 PM | #2 |
Thanks for the update. You need to find time to install all them upgrades.
12-20-2020, 05:31 PM | #3 |
Had my 2020 TT250 since April, just over 2000 miles. Have changed oil 3 times and adjusted valves twice. Rejetted. Went to 42 rear (stock 17 front) for lower revs at speed. Just replaced chain, and I'm replacing the front sprocket because I think it is wallered out. Tires are about done. Battery sucks and if I don't get it started on the first or 2nd try (and keep it running), I have to boost. Ordered a national Cycle Deflector (U-clamp) and will install that and heated over grips soon. Already have feed for electric vest.
12-20-2020, 06:46 PM | #4 | |
BuffaloChinaRider on Youtube Bashan Storm 250 (2018) Apollo Db-36 Deluxe (2019) |
12-20-2020, 06:49 PM | #5 | |
03-19-2021, 10:47 AM | #6 |
2020 Storm
I just have a couple of miles on my 2020 Bashan Storm:
https://www.chinariders.net/showpost...15&postcount=1 I heated it up on a ~2mile drive to drop the oil and replace it with some T4 15-20 and while I was takiong off from a stop/intersectio, I notice some chatter on the clutch as I started. New clutch, cheap oil I guess. I will ride it again this weekend and see if the new oil helps that. I was going to get a Hawk EFI but decided on the carb instead. It seems like the same bike otherwise! I want to rejet and adjust the valves. Will dissect the Cat bulb later on and rejet again as needed. Will these jets fit the carb on this 2020 Bashan Storm? https://www.amazon.com/dp/B07PQ6K84T...v_ov_lig_dp_it This jet kit has 10 pilot and 10 main jets Description on Amazon if that link fails is: Supermotorparts 10Pcs Carburetor Main Jets kit & 10Pcs Slow Pilot Jets for PWK Keihin OKO CVK PWM |
03-19-2021, 02:45 PM | #7 |
Depends on whether your carburetor uses those Keihin style jets. If your not sure what your carburetor uses you will have to find out which may require opening up your carburetor. Read this post paying attention to the carburetor and jet discussion.
http://www.chinariders.net/showthread.php?t=28343 |
