Carb, skid plate?
So I just ordered a TBR7 and the more I think about it the more excited I am to take it on adventured! I tend to love my machines lol. Reading a lot about them, I want to order a new carb before the bike even shows up, and are their any skid plates that will fit? Can any one recommend either a mikuni or decent quality carb? I wanna make sure I get the right thing and where else better to go than a forum of folk who love these machines?!
At what point do I have too many machines? |
My 2019 has a pretty decent carb, all that was needed was jets to make it spicy. I suppose you should get the bike put together and run it first but I'm 99.9999999% sure you will be disappointed in throttle response - I would just do the work before even going through that. At least order the jets (&17 tooth sprocket) now. You probably don't need to buy a carb for it yet just to get going.
I would wait on the new carb and work out what comes with the bike by getting some new jets. Put a few hundred miles on the bike and consider my options. In my opinion, the only reason to upgrade is to get performance improvement, unless you determine the stock carb is not tunable (that after putting in a good effort) These bikes are somewhat erratic idling so, in the first few hundred miles, they will demonstrate carburetor like symptoms that are likely more of a break in issue.
#6 | |
Otherwise, for ease of installation and tuning, it is really hard to beat the VM26 as long as it uses the genuine Mikuni jets. Not really much of a performance upgrade, but it's so easy to dial in that even a complete novice can generally get it sorted with minimal effort thanks to the vast amount of information on the jetting from numerous members here. Beyond that, the PZ30B (pumper) is the only other real upgrade to be had. The hard part is getting one that uses genuine jets on the pilot, which is a hit or miss affair. I loved having that accelerator pump, and to be honest I kind of miss it lol.
I had a lot of problems finding a manifold for my PE30, ended up using a crf230 manifold with a 3d printed spacer. I don't think it's that much of an improvement over the VM26 that it came with after I did the jet kit mod to it.
#8 | |
And yes, the biggest challenge is the intake when trying to mount any of the socket style carbs. For 95% of the people here, there is no real reason to go "bigger." Either get a PZ30B for the accelerator pump, or the VM26 for better running and ease of tuning, and be happy. I could hit 68mph with an exhaust, modded air box, and full exhaust on my first Hawk with the right gearing, and it only had a VM26. Sure, my current bike pulls a lot harder, and definitely has more power, but that's because of the cam and head porting, not the PE30. The PE30 helped the ported head realize it's potential, and the cam just opened that up more.
I agree. A stock PZ30 is plenty for these bikes in stock form and I think for most stage 1 mods such as an exhaust with the proper jetting. I have one is a beautifully functioning carburetor and I think the casting on them is better than most aftermarket carbs. The PZ30b, ah, that is a sweet performance improvement I think for stock and stage 1 mods and I can't find any good reason to replace one on my HAWK. People talk about the acceleration of a PE or PWK but I say in my limited experience with stage 1 mods I don't find them better than a PZ30b in terms of acceleration. A great advantage to the PE and PWK carburetors is their side tuning capabilities but once you get a carburetor dialed in your not fiddling with it that much anyway.
#10 |
Wow! thanks everyone! everyone is very helpful in this forum. I'm part of a lot of other forums and can say whole heartedly that ive never had any one be this helpful! I'm thinking go with a PZ30b for the accelerator pump, can anyone recommend an exhaust? Also anyone have a good source where I can get a PZ30b and not have to wait 3 months to get it?
#11 |
#12 |
The 30 is too big unless you are planning on doing head work. Honestly I would stick with the stock carb or a better version of the stock carb like the vm26 unless you are planning to go big or go home.
I have regrets about putting an aftermarket exhaust on my bike. Sometimes I wish I left it with stock exhaust, but gutted the cat, and just the snorkel removal mod. The problem was I couldn't find good pilot jets. Mains are easy to find. |
#14 | |
#15 |
https://www.amazon.com/Cycra-Armor-P.../dp/B07C91JDRX
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Skid plate I got for my bike - Almost the exact same as the Orion XRB250L, fits perfect. It is polymer, a bit stronger than plastic, but for now until it busts up; I've gone through some pretty rough stuff and didn't even put any marks on it except surface. And I heard it bottom out, so it must be pretty tough! Was going to get an aluminum but out of my price range. Anyway, metal retaining bar in front that attaches with two 8mm bolts, then the rear slides into place using the frame as a latch point. I used some metal washers to extend the opening on the skid plate itself - without them when attached the front points downward. . . Unless you've got a plate already and I'm just posting for nothing lol Second the VM26 from MegaDan - That's what I put on mine, without jetting 'twas much nicer on startup. My vacuum hose leading to the intake manifold was also smashed between the gas tank and engine and would cause stalling - thought it was the PZ30 but nope. Found out about the vacuum hose after I removed the stock carb.
|2020 X-Pro Titan DLX| <-- FOR SALE!! |
