Old 11-20-2020, 06:53 PM   #1
JerseyTBR7   JerseyTBR7 is offline
What IMS shifter fits a 2021 TBR7?
I know the IMS 312223 flightline folding shift lever does not fit.
Which one fits a 2021 TBR7?
A quality that will hold up would be great.
IMS looks good.
Old 11-20-2020, 07:53 PM   #2
Musictrek   Musictrek is offline
Musictrek's Avatar
IMS looks good.
Im using this IMS with good results on my Brozz. Interesting that it wont fit the TBR
https://www.amazon.com/dp/B000UKO37Q...SIN=B000UKO37Q
https://radpaul.weebly.com/brozz-and-hawk-250.html
Old 11-20-2020, 08:56 PM   #3
The spline fits but bend on arm is too far inward blocked by the engine casing.
Old 11-21-2020, 09:48 AM   #4
alex_in_az   alex_in_az is offline
sounds like it's time to break out the hammer and bench vice to make it fit
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
Old 11-21-2020, 10:02 AM   #5
Funny, that is exactly what I did to the stock one after some trail riding to get it back to position.
Was looking for suggestions on which one people purchase that is an exact fit.
Old 11-23-2020, 02:05 PM   #6
I would up just bending it to fit in the end for now.
Attached are the pictures of the factory TBR7 shifter after I bent it back into place and IMS bent into position too.
https://postimg.cc/gallery/cfCQpGV
The IMS is definitely thicker.
Also, the stock shifter has a long shaft with a bolt that catches in a groove, where the IMS just pressure tightens on the end of the shaft.
Anybody have a link for a shifter that fits without bending it and has the proper shaft fit?
File Type: jpg Stock_Shifter.jpg (157 Bytes, 449 views)
File Type: jpg IMS_Shifter.jpg (157 Bytes, 495 views)
