Old 11-10-2020, 11:20 AM   #1
OregonDewd   OregonDewd is offline
Preferred Oil
This is probably a stupid question. I have a Brozz on its way and it's my first bike. Looking for what you guys use for oil. Was going to pull the trigger on the following but it says "heavy duty diesel"?
https://www.walmart.com/ip/Shell-Rot...xoCCgYQAvD_BwE
Old 11-10-2020, 11:22 AM   #2
gwowzer   gwowzer is offline
Yup, that's what I use.
Old 11-10-2020, 11:32 AM   #3
Same here.. changed the oil so far at 20mi and again at 120min... next stop 500 miles and then every 1k
Old 11-10-2020, 12:21 PM   #4
cycleway4   cycleway4 is offline
yes,....thats it. great choice
<div>Steve
2006 Roketa DB-07A/RSX-200E
2008 Roketa 250 Scooter
2019 Brozz 250
Old 11-10-2020, 12:25 PM   #5
Just curious. Why does it label as diesel?
Old 11-10-2020, 01:34 PM   #6
JerseyTBR7   JerseyTBR7 is offline
I use the same oil.
Old 11-10-2020, 01:51 PM   #7
franque   franque is offline
It's for big trucks, it has additives that modern car oils lack, and doesn't have the friction modifiers that modern car oils have that wreak havoc on a wet clutch.
Old 11-10-2020, 01:59 PM   #8
Walmart brand full synthetic motorcycle oil in my TBR7
TeeBee likes it!
Old 11-10-2020, 02:00 PM   #9
OregonDewd....Its labeled for Diesel as it meets all the requirements and specifications set forth by the Diesel engine manufacturers. Regular automotive gas engine oils do not meet these standards. Diesel oil can be used in automotive gas engines, although not recommended. API-rated diesel CC or CD oils do not meet the engine-cleanliness parameters set forth for oils rated SF for gasoline engines,..also typically do not have any anti-friction modifiers. Shell Rotella (specifically Rotella T 15w-40) is commonly used in motorcycles because it meets the standards that are recommended for motorcycles, such as JASO-MA and thus has no friction modifiers (not "Energy Conserving") that are not recommended for wet clutches.
<div>Steve
2019 Brozz 250
Old 11-10-2020, 05:10 PM   #10
That makes sense. I'm going with this one, thanks all!
