10-30-2020, 11:20 AM | #1 |
engine speed versus road speed
I did a calculator for engine speed with a variety of sprocket sizes for my TBR7. does this match up with what you guys are seeing?
10-30-2020, 11:31 AM | #2 |
You can check it against gear commander's website. Just load the RPS Hawk for the info as the TBR will be the same as far as gear ratios. Make sure you have the correct rear tire size inputted. https://www.gearingcommander.com/
10-30-2020, 12:33 PM | #3 |
I have no idea, I don't have a tach and my speedometer is all over the board. Also my tire is taller than stock.
10-30-2020, 01:12 PM | #4 |
the stock speedo is garbage, it was the 1st thing I changed. I have a digital one that you can set to the exact circumference of your wheel. I calibrated mine with GPS so it's dead nuts right
10-30-2020, 01:23 PM | #5 |
The digital ones are expensive these days. I hope to get one when the price comes back down on them. Til then, I just assume the top speed is probably not enough to get me serious speeding ticket. Lol
10-30-2020, 03:48 PM | #6 |
Can you recommend a least effort plug and play swap speedo?
10-30-2020, 03:59 PM | #7 |
I got mine from board member NzBrakelathes, not sure if he's still selling them or not. anyway it was a really easy install and came with an install guide and everything you needed. quality was typical china but the price was right
