10-11-2020, 12:22 AM | #1 |
Brozz Front Brake Caliper Upgrade?
Hey All,
Been enjoying my Brozz for the last year using all the information from this site. However, the front brake on my Brozz has always been really weak. I "bedded" in the pads with some sandpaper and that helped a little bit. I was researching and found that the Hawk has a 2 piston front caliper while my Brozz is a 1 piston "hockey puck" style caliper. Will the Hawk front caliper work on mine? My Brozz has regular forks, not the newer USD fork model. Thanks for the help! |
10-12-2020, 11:39 AM | #2 |
Any ideas? I think it would be a worthwhile upgrade from the single piston caliper?
10-12-2020, 09:35 PM | #3 |
Sounds to me like you are having some sort of other underlying issue. The front brake on mine has always been very strong. Maybe try another bleed and double check all your fittings? Make sure everything is installed right and tightened.
10-12-2020, 09:37 PM | #4 |
Did you change out your brake fluid from stock?
10-12-2020, 11:44 PM | #5 |
Yup, I did a gravity bleed and used DOT 4, there doesn't seem to be any air in the lines, the lever isn't spongy.
To speed up bedding in the brakes, I used 60 grit on the rotor and pads and that helped. I took it out again today and noticed something I didn't before; when sitting at a traffic light with the brake lever pulled, it will slowly sink down until touching the bar. If I release the lever and squeeze again, it works. Looks like the master cylinder piston seal is leaking? If so, is it worth repairing, or should I get a complete master cylinder like this one from Amazon? https://www.amazon.com/gp/product/B01B1BNQTS/ref=crt_ewc_title_dp_2?ie=UTF8&psc=1&smid=A2L77EE7 U53NWQ Thanks |
10-13-2020, 09:30 AM | #6 | |
For $16 its worth a try but normally a brake master cyl and caliper is matched so a dual piston caliper may? need more fluid to move so its matched to the master cyl with a bigger bore.? I don't mean to over think this but right now your brake sucks , most likely from a bad master cyl . Its probably not worth the effort to rebuild what you have. I would take a chance on the $16 one and see what happens. If i was not happy i would replace the caliper and master cyl with a matched set (assuming the caliper is a bolt on rather than make brackets). Just my thoughts Paul |
10-14-2020, 05:32 AM | #7 |
[QUOTE I took it out again today and noticed something I didn't before; when sitting at a traffic light with the brake lever pulled, it will slowly sink down until touching the bar. If I release the lever and squeeze again, it works. Looks like the master cylinder piston seal is leaking.[/QUOTE]
The same thing happened to me right after I bled my brakes with new fluid. My bike was new and Jeff shipped me an all new sealed front brake assembly, (master cylinder, line , caliper and pads). I sanded the new pads, bedded them and called it a day. They still suck, no bite! Compounding the issue is the rear drums on my bike.
2019 Z 400 2020 Tan Recon 2021 KLX 300 2022 GPX FSE 450R |
10-26-2020, 10:36 AM | #8 |
I swapped out the master cylinder with the one I linked to on Amazon in my prior text, works great and slightly more fluid capacity too. It fits just like the original except the fitting is on the front instead of the side. I like that design better, keeps the brake line out of the way of the triple tree.
I also fitted an SS brake line, https://www.amazon.com/gp/product/B07F9NB1NT/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 I got this in the 120CM size, which was perfect. The bends at the end are great, direct bolt on. For 18 bucks, it was a great inexpensive upgrade. This fixed the leakdown problem. It changed the front brake performance from dangerous to just OK. Still looking for a cheap caliper upgrade. Anyone else got any ideas? I think the extra pad contact surface and pressure from the dual piston model from the hawk might help. Chris |
